Тема: P31E1 00C0 EV/HEV HV System Interlock Error EVC-305
Hello guys sorry for my English but unfortunately I do not know Russian.
I'm have a crashed Nissan Leaf 2011.
The front airbags (driver and passanger) has been deploy.
I had already changed some parts and fix other parts to confirm that the car works well. Unfortunately the car dont enter in Drive Mode and don't Charge.
I clean all strange DTC errors with Leaf Spy Pro, but i have a few fixes DTC Errors.
https://i.imgur.com/AYnMeEg.png
I dont have the Heater Water Pump connected because of a leak. But i have all high voltage cables connected and all 12v cables connected, except the headlights and exterior lights.
Some people tell me when you have a crash with the Nissan Leaf the software lock the high voltage connection and i need to unlock the system with the Nissan Consult 3 Plus. But some people say that it is not necessary. So I do not know who to believe.
My major issue its the HV System Interlock Error EVC-305. I check the service plug, the HV Cables, The HV Cables Connections and all seems to be in order.
Any ideas?
Tnks 4 your help
Re: P31E1 00C0 EV/HEV HV System Interlock Error EVC-305
english know here:
http://mynissanleaf.com/
I allready post in the English forum. But unfortunately I did not have any help.
4 (2019-01-02 15:46:50 отредактировано LKA)
you can believe only service manual.
diagnosis procedure about P31E1 writed in page 351 in EVC.pdf
you have to measure voltages and check fuses
