goodwin_c⇓ пишет:так как начнется дозарядка 12 вольтовой
это не так.
дозарядка не начнется. речь там идет об автоматическом контроле.
Precaution for Removing 12V Battery INFOID:0000000010119470
1. Check that EVSE is not connected.
NOTE:
If EVSE is connected, the air conditioning system may be automatically activated by the timer A/C function.
2. Turn the power switch OFF → ON → OFF. Get out of the vehicle. Close all doors (including back door).
3. Check that the charge status indicator lamp does not blink and wait for 5 minutes or more.
NOTE:
If the battery is removed within 5 minutes after the power switch is turned OFF, plural DTCs may be
detected.
4. Remove 12V battery within 1 hour after turning the power switch OFF → ON → OFF.
NOTE:
• The 12V battery automatic charge control may start automatically even when the power switch is in
OFF state.
• Once the power switch is turned ON → OFF, the 12V battery automatic charge control does not start for
approximately 1 hour.
или в таком виде:
Precautions for Removing Battery Terminal INFOID:0000000010121198
• When removing the 12V battery terminal, turn OFF the power
switch and wait at least 5 minutes.
NOTE:
ECU may be active for several minutes after the power switch is
turned OFF. If the battery terminal is removed before ECU stops,
then a DTC detection error or ECU data corruption may occur.
• Always disconnect the battery terminal within 60 minutes after
turning OFF the power switch. Even when the power switch is
OFF, the 12V battery automatic charge control may automatically
start after a lapse of 60 minutes from power switch OFF.
п.с. про 30% не встречал (или не помню )))
Nissan Leaf 30X 2016
