1. поехать и снова перепришить ключи
2. забить, смысл дёргаться, если все работает?
B26FC KEY REGISTRATION
Possible cause
• Improper registration operation
• Intelligent Key
• BCM
PERFORM DTC CONFIRMATION PROCEDURE
1. Perform initialization of BCM and registration of all Intelligent Keys using CONSULT. Refer to the CONSULT Immobilizer mode and follow the on screen instructions.
2. Check DTC in “Self Diagnostic Result” of “BCM” using CONSULT.
Is DTC detected?
YES >> Go to SEC-98, "Diagnosis Procedure"
NO >> Inspection End.
REPLACE INTELLIGENT KEY
1. Prepare Intelligent Key that matches the vehicle.
2. Perform initialization of BCM and registration of Intelligent Key using CONSULT. Refer to the CONSULT Immobilizer mode and follow the on screen instructions.
3. Check DTC in “Self Diagnostic Result” of “BCM” using CONSULT.
Is DTC detected?
YES >> GO TO 2.
REPLACE BCM
1. Replace BCM. Refer to BCS-72, "Removal and Installation".
2.Perform initialization of BCM and registration of all Intelligent Keys using CONSULT. Refer to the CONSULT Immobilizer mode and follow the on screen instructions.
>> Inspection End.
