Доброго дня.
"Датчик света" точнее optical sensor, есть у всех и находится под лобовым.
Ты точно понимаешь как это работает?
Description
• BCM detects the combination switch condition with the combination switch reading function.
• BCM supplies voltage to the optical sensor when the power switch is turned ON or ACC.
• Optical sensor converts outside brightness (lux) to voltage and transmits the optical sensor signal to BCM.
• BCM filters outside brightness based on the optical sensor signal and judges outside brightness.
• BCM detects change status of outside brightness according to outside brightness from the optical sensor
signal and filtered outside brightness. Based on the change status, BCM judges ON/OFF condition of the
exterior lamp.
• BCM transmits each request signal to IPDM E/R and combination meter via CAN communication, according
to ON/OFF condition by the auto light function.
